Discussion forum
CAD discussion |
How do I turn these 2d shapes into 3d |
Post Reply |
Author | |
Aerodynamicguy
Newbie Joined: 24.Apr.2015 Location: Australia Using: Autocad2016 Status: Offline Points: 5 |
Topic: How do I turn these 2d shapes into 3d Posted: 24.Apr.2015 at 05:01 |
Hello,
I have created the top view and side view but I cannot combine them to create a smooth 3d shell. If you know of a tutorial on how to do this please share a link. Otherwise how can I get these two 2d shapes to combine into 3d. uploads/554801/How.dwg |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 24.Apr.2015 at 11:58 |
Extrude each shape in the proper direction then run the INTERFERE commnand.
Edited by John Connor - 24.Apr.2015 at 11:58 |
<<AutoCAD 2015>> |
John Connor
Posted: 24.Apr.2015 at 12:04 |
One possible outcome. I had to copy and union one of the 3D objects before running the INTERFERE command. |
<<AutoCAD 2015>> |
Aerodynamicguy
Posted: 26.Apr.2015 at 09:19 |
I finally figured it out.
I had to extrude both shapes then line them up. Then click intersect. What I want to know now is how to make it rounded like a plane's fuselage. Then I can test it with CFD. Edited by Aerodynamicguy - 26.Apr.2015 at 11:01 |
John Connor
Posted: 26.Apr.2015 at 13:19 |
Rounded? You might try the Fillet command with the Chain option.
<<AutoCAD 2015>> |
Aerodynamicguy
Posted: 26.Apr.2015 at 14:37 |
Using the sideline and top line as a guide for the rounding.
Edited by Aerodynamicguy - 26.Apr.2015 at 14:37 |
SEANT
Groupie Joined: 09.Jan.2012 Location: United States Using: AutoCAD 2016 Status: Offline Points: 31 |
Posted: 26.Apr.2015 at 16:48 |
It looks like you need to use surfacing techniques to get to that kind of shape. Your original geometry looked symmetrical enough so I limited it to one quadrant. I then used 4 copies with the SCULP command to get the solid.uploads/244286/HowBySurfQuad.dwg
Aerodynamicguy
Posted: 27.Apr.2015 at 01:24 |
Yes that is what I want.
When I typed in "SCULPT" it came up with "SURFSCULPT" I then clicked on the solid and clicked enter. It said "solid creation failed, no watertight volume detected". Have I missed a step? Will this surfsculpt work if the object is flat on the bottom like a a non symmetrical airfoil? |
SEANT
Posted: 27.Apr.2015 at 09:14 |
Yes, the command name is SURFSCULPT, though the Ribbon icon just says "Sculpt".
The command just uses surfaces, and if the surfaces selected enclose a volume then a 3D Solid will be created. It should not matter id one of the surfaces are flat.
Post Reply | |
Tweet
This page was generated in 0,414 seconds.
