RSS discussions
Discussion Discussion forum
Topic Closedneed 2d dxf file
 Post Reply Post Reply
Author
BrianPfeifer View Drop Down
Newbie
Newbie
Using: Bobcad
Status: Offline
Direct Link To This Post Topic: need 2d dxf file
    Posted: 16.Oct.2015 at 18:50
Yes. I got the file but i am missing the "o"s in a couple of the words. Can't really explain why. Everything else seems to be there
Brian Pfeifer
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Oct.2015 at 00:31
You've lost your "O's"?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Bobcad
Status: Offline
Direct Link To This Post Posted: 15.Oct.2015 at 19:53
i downloaded the dwg file and saved it as a dxf. it worked fine. The problem is when i downloaded the dwg file i'm missing some the O's in a couple of the words, ie LIVERP  L.
Brian Pfeifer
Back to Top
Newbie
Newbie
Using: Bobcad
Status: Offline
Direct Link To This Post Posted: 15.Oct.2015 at 19:44
Thanks John.
b r i a n p f e i f e r a t s b c g l o b a l d o t n e t
Brian Pfeifer
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Oct.2015 at 13:11
Originally posted by BrianPfeifer BrianPfeifer wrote:
Does anyone have(or can get me) a 2d dxf file of the liverpool soccer logo?
Is this what you are looking for?
http://www.cadforum.cz/catalog_en/?q=liverpool
BobCad can import a .dwg file according to what I found online.  You could "save as" a .dxf couldn't you?
Well I open the drawing and did a DXFOUT saving to AutoCAD 2000 file format and the resultant file is almost 1.2MB.
If you want it I can email it to you.  Post your email address like this....
y o u r e m a i l a d d y AT u s a DOT c o m
Understand?
Edited by John Connor - 14.Oct.2015 at 13:16
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Oct.2015 at 13:06
This site is so screwed up at times.
Why doesn't the Insert Image work?  WTF??
Let's try again shall we?
Amazing!  Got it to work finally.
Edited by John Connor - 14.Oct.2015 at 13:08
<<AutoCAD 2015>>
Back to Top
Robert_D View Drop Down
Senior Member
Senior Member
Using: BricsCAD v25, AutoCAD2006
Status: Offline
Direct Link To This Post Posted: 14.Oct.2015 at 00:05
Did you look in CAD Blocks here?
Can Bobcad open dwg.s?
Back to Top
Newbie
Newbie
Using: Bobcad
Status: Offline
Direct Link To This Post Posted: 13.Oct.2015 at 23:11
Brian Pfeifer
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,063 seconds.
