RSS discussions
Discussion Discussion forum
Topic ClosedMoving cameras in ACAD 2105
 Post Reply Post Reply
Author
woody124 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Moving cameras in ACAD 2105
    Posted: 12.Apr.2016 at 22:19
I am trying to make a walk through in a model of a 3D building I made in AutoCAD 2015.  I want to be able to go into a room and stop, pan around the room and maybe change the FOV and then proceed to the next room and get a good idea of what is in every room without everything appearing to choppy.  My problem is I am using the Motion Path Animation and you are either stuck with having the camera follow a path with the camera target following the same path or you have to give the camera a target and as you move it stays focused on the same point.  I don't know what to do when you go to the next room?  I have used 3DS Max and you have better camera controls in it but is there a better way to control the camera in ACAD that I am not aware of it?  Any help would be appreciated.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,160 seconds.
