RSS discussions
Discussion Discussion forum
Topic Closedcreo auxiliary view
 Post Reply Post Reply
Author
yskandre View Drop Down
Newbie
Newbie
Using: Creo parametric 3.0
Status: Offline
Direct Link To This Post Topic: creo auxiliary view
    Posted: 25.Apr.2016 at 05:21
Hello, I have a problem. I need two auxiliary views of this drawing to show the real diameter of a hole.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Apr.2016 at 11:31
Create a 3D model and extract the 2D views that you need from the model.  Can't that be done in Creo?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Apr.2016 at 18:57
I did ! The problem is the auxiliary views
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Apr.2016 at 20:19
What?  You think the views are incorrect?  I don't see why you would have a problem creating an auxiliary view.  Please explain.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 26.Apr.2016 at 00:28
I don't know from where the auxiliary view should be taken in order to have a view showing the real diameter of the hole. I know that I need two auxiliary views to get that one.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 26.Apr.2016 at 00:58
Can you export the 3D model in a file type that could be imported by AutoCAD?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,094 seconds.
