Over 1.095.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
RSS discussions
Discussion Discussion forum
Topic ClosedGoogle Drive File Stream
 Post Reply Post Reply
Author
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Arkance Systems CZ
Using: Autodesk software
Status: Offline
Direct Link To This Post Topic: Google Drive File Stream
    Posted: 05.Mar.2019 at 16:09
I think the easiest way is to use the native Autodesk's tools for this - the A360 cloud (Autodesk Drive) or Autodesk Vault.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner
Back to Top
gegenytibor View Drop Down
Groupie
Groupie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Posted: 01.Mar.2019 at 11:32
Helllo All,
Do you have any experience with use Google File Stream and AutoCAD files?
We tried to use but Autocad not give any sign if the file is open at another user.
It can cause big mistakes if two or more user are in one file at the same time.
Any ideas?
What other method do you use for share and work with autocad files?
Thanks for the answers!
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,076 seconds.
