Discussion forum
CAD discussion |
arc and circle not smooth |
Post Reply | Page 12> |
Author | |||||||||
Kate28
Newbie Joined: 03.May.2019 Location: Philippines Using: AUTOCAD2017 Status: Offline Points: 9 |
Topic: arc and circle not smooth Posted: 03.May.2019 at 07:11 |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 03.May.2019 at 07:41 | ||||||||
It looks like a scanned/vectorized drawing - how did you make it? You will need to grip-edit the disjoint endpoints.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
Kate28
Posted: 03.May.2019 at 07:46 | ||||||||
I just screenshot my drawing
jiteshnakum86
Newbie Joined: 08.Apr.2014 Location: India Using: AutoCAD2007 to 2019, Inventor2012, AutoCAD LT Status: Offline Points: 2 |
Posted: 03.May.2019 at 08:19 | ||||||||
Please go to below step. Step 1 - Type "Op" (Option) in command bar and then Press Enter key. Step 2 - Select 2nd Tab named "Display" from the Opened window Step 3 - Enter Display resolution as a "20000" for arc and circle smoothness at right side. Step 4 - Select tab "apply" and then "Ok" at bottom of the entire window. Step 5 - close this window. Please check your arc and circle smoothness...!!! Hopefully this will work for you...!!! Thanks & Regards Jitesh Nakum Project Manager LTTS |
Warm Regards,
Jitesh Nakum Manager Larsen & Toubro Ltd |
Kate28
Posted: 03.May.2019 at 08:46 | ||||||||
Hi Actually I did that already, Display resolution is 20000. but also doesn't work.
Kate28
Posted: 03.May.2019 at 08:49 | ||||||||
rebellio
Senior Member Joined: 04.Mar.2009 Location: Netherlands Using: Autocad 2018 Status: Offline Points: 125 |
Posted: 03.May.2019 at 11:11 | ||||||||
post the drawing, it will make it a lot easier to solve (or not)
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 629 |
Posted: 03.May.2019 at 14:37 | ||||||||
I think the question was about how you drew that, i.e. how you made the drawing, not how you made the image. Some of those kinked curves look like they could be Arcs, but some clearly have varying radius, so they can't be [at least not single] Arcs. I agree -- post the drawing file. Also, on the 20000 view resolution, did you REGEN after changing the setting?
Kate28
Posted: 04.May.2019 at 03:55 | ||||||||
uploads/813674/Flower.dwg
yes, after I change i used command REGEN
rebellio
Posted: 06.May.2019 at 08:05 | ||||||||
Seems ok on my pc, did you tried the regenall command?
Also check the _GRAPHICSCONFIG settings..... and... set shademode on 2dwireframe Edited by rebellio - 06.May.2019 at 11:09 |
Tweet
This page was generated in 0,375 seconds.
