CZ | EN | DE
Login or
registration
  Visitors: 10323
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedSIZE ISSUE
 Post Reply Post Reply
Author
Zuhaib View Drop Down
Groupie
Groupie
Using: AUTOCAD 2018
Status: Offline
Direct Link To This Post Topic: SIZE ISSUE
    Posted: 18.Dec.2019 at 09:45
Dear All
hope you all are well.
I am facing a problem of drawing size. I am working on interior detail drawing. My working drawing size in 9MB, When I remove everything from the drawing and purge it all and then save it to my computer, the drawing size should be reduce but the drawing size is remain as before purge. Even when I am starting a new drawing and saving it without draw any thing, the drawing size is 4.5MB.
What should I do for saving it in actual size?
I will be very thankful to you.
THANKING YOU
REGARD: ZUHAIB KHAN
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Dec.2019 at 13:20
Is there any evidence of .DGN linetypes or text being loaded?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: AUTOCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Dec.2019 at 13:43
There are some custom hatch patterns loaded, also some useless textstyles & line types are loaded as you can see in attach image. I don't know where its(linetypes & tex styles) comes from. also dont know how to delete or remove it.
THANKING YOU
REGARD: ZUHAIB KHAN
Back to Top
aqeel222 View Drop Down
Groupie
Groupie
Using: AutoCAD2019
Status: Offline
Direct Link To This Post Posted: 19.Dec.2019 at 14:13
1- start from new dwg.
2-use dwg-purge external command (download & install first)
3-saveas as dwt format acad.dwt / any name.
4- close.
5- start new dwg with the last created dwt file.
 I hope it will solve your issue.
Edited by aqeel222 - 19.Dec.2019 at 14:16
Back to Top
Groupie
Groupie
Using: AUTOCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Dec.2019 at 10:47
ISSUE IS NOT RESOLVED YET CryCry
THANKING YOU
REGARD: ZUHAIB KHAN
Back to Top
rebellio View Drop Down
Senior Member
Senior Member
Using: Autocad 2018
Status: Offline
Direct Link To This Post Posted: 20.Dec.2019 at 11:33
Can you upload the file so we can have a look?
Back to Top
Groupie
Groupie
Using: AUTOCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Dec.2019 at 12:14
YES
THANKING YOU
REGARD: ZUHAIB KHAN
Back to Top
Groupie
Groupie
Using: AUTOCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Dec.2019 at 12:24
NOT UPLOADING DUE TO LRGE FILE SIZE.
THANKING YOU
REGARD: ZUHAIB KHAN
Back to Top
Groupie
Groupie
Using: AUTOCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Dec.2019 at 12:32
If you guys don't mind so we can talk on whatsapp  . May be the issue can resolve on whatsapp by doing clear chat.
+923042210396
THANKING YOU
REGARD: ZUHAIB KHAN
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Dec.2019 at 13:13
If all you require is a clean acad.dwt (or acadiso.dwt) delete what is being used by AutoCAD now and rename the backup version which is in the same directory.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,344 seconds.
