Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
RSS discussions
Discussion Discussion forum
Topic ClosedSeven commands that every user should know
 Post Reply Post Reply
Author
Cadlover04 View Drop Down
Newbie
Newbie
Using: autocad 2020
Status: Offline
Direct Link To This Post Topic: Seven commands that every user should know
    Posted: 22.Sep.2020 at 15:39
Hello Friends in this tutorial i will show you: 1- FILETABPREVIEW; Controls the type of preview when you hover over a drawing file tab 2- VPCONTROL: Controls whether the options for viewports, views, and visual styles are displayed in the upper-left corner of every viewport 3- NAVVCUBE : Indicates the current viewing direction. Dragging or clicking the ViewCube rotates the scene 4- NAVBAR : Provides access to viewing tools from a unified interface. 5- CLI command: Use the shortcut CTRL+9 or enter the command CLI to toggle on the command line. 6- FILETAB: Displays the file tabs at the top of the drawing area. 7- Quick properties: How to disable or turn off the the Quick Properties pop-up when selecting an object in an AutoCAD drawing. The pop-up shows a short list of properties of the object.
Edited by Cadlover04 - 22.Sep.2020 at 15:42
between the devil and the deep sea
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,070 seconds.
