Discussion forum
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz. |
DWF - AUTOPUBLISH |
Post Reply ![]() |
Author | |
Tvri ![]() Newbie ![]() Joined: 04.Nov.2020 Location: Israel Using: Autocad2019 Status: Offline Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 04.Nov.2020 at 21:50 |
Hi
Since I install the DWF Free Software, every time that I save the drawing, Autopublish run and create a file for every layout ( I use a lot of layouts) in DWFx format. This takes a lot of time and place in memory. I deleted the DWF Software but this phenomene continues. Does anyone knows how to stop the automatic Autopublish and creation of DWFx files? Thanks to all. |
philippe JOSEPH ![]() Senior Member ![]() Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1226 |
Hello Tvri, we had this for any print when the .ctb is/are located on a distant server, instead relocate your .ctb ( s )'s directory on your (C) disk by doing a copy of the .ctb and do a test.
Eventually ask how to do it.
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,063 seconds.
