Discussion forum
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz. |
special dimensions |
Post Reply ![]() |
Author | |
beardencad ![]() Newbie ![]() Joined: 21.Apr.2014 Location: Canada Using: autocad 2017 Status: Offline Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 20.Nov.2020 at 16:03 |
I everyone's! I need a imperial dimension font without the prefix and suffix ex: 9 feet and 2 inches =
appearance like this: 9-2 (instead of 9'-2") Does anyone can help me to how to create my own dimension font ? (or already created one?) For AutoCAD classic Thank you very much all of you!! Denis
John Connor ![]() Senior Member ![]() Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7090 |
Why? The feet and inches symbols are a function of the unit format which in this case can be either Architectural or Engineering. You could always choose to use Decimal.
<<AutoCAD 2015>> |
philippe JOSEPH ![]() Senior Member ![]() Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1228 |
Yes I agree with John that the "units" should be part of the dimensions but you can also use the "fractional" units as shown but without feet/foot :
See also on the internet : ![]() Edited by philippe JOSEPH - 29.Nov.2020 at 12:43 |
Kent Cooper ![]() Senior Member ![]() Joined: 12.Mar.2013 Location: United States Using: AutoCAD2019 Status: Offline Points: 538 |
https://forums.autodesk.com/t5/autocad-forum/make-a-dimension-style-with-no-foot-or-inch-marks/m-p/7652743/highlight/true#M913344
Edited by Kent Cooper - 07.Dec.2020 at 14:16 |
Space matters. The reason why I am looking for that kind of "dimension" is: I realize a lot of "fire protection sprinkler installation" in many type of buildings, condos etc. Because I keep all the walls, door frames, and all the architecture stuff, I have to put dimensions on "all the lines" [the long and short one's] for fabrication on site, so my drawings becomes so heavy of informations, it is hard to read dimensions sometimes. Some sprinklers companies already use that kind of dimensions in Quebec province (Canada) but don't want share their dimensions. So this is it, this is the reasons of my request!
I would like to thank you every one who took time to answer my post! Sorry for all the misspelling in my sentences. My regards,
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,109 seconds.
