Please abide by the
rules of this forum.
Author |
Topic Search Topic Options
shakir.iqbal
Newbie
Using: AutoCAD all versions, Revit, Tekla Structures
Status: Offline
Topic: DeLaval Parallel Rotary PR1500 & PR2100 Posted: 07.Sep.2021 at 18:46 |
Hi, Is your problem resolved or you still looking for help?
Shakir Iqbal Seasoned CAD Guru https://www.fiverr.com/shakiriqbal482
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 01.Sep.2021 at 19:31 |
royalhorn wrote:
Sorry for not answering. I'm working like 5 hours. I will try this command when i go home. Thank you so much for your interest. |
In AutoCAD I believe the command is IMAGEATTACH. For the drawing depicted above I inserted the image on a layer named "Image" so that when the time came I could turn off or freeze the layer so it would not plot.
Edited by John Connor - 01.Sep.2021 at 19:33
<<AutoCAD 2015>>
royalhorn
Newbie
Using: autocad2021
Status: Offline
Posted: 01.Sep.2021 at 15:45 |
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 01.Sep.2021 at 15:09 |
I waited an hour for your reply but got nothing. No response? Oh well, can't say I did not try to help. Good luck on your homework assignment. Got to go now. Bye.
Edited by John Connor - 01.Sep.2021 at 15:09
<<AutoCAD 2015>>
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 01.Sep.2021 at 14:06 |
Here is an example of what can be accomplished via the insert image command in nanoCAD which is an AutoCAD clone. It took me about 20 minutes while I was having my morning coffee.
<<AutoCAD 2015>>
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 01.Sep.2021 at 13:59 |
You never once mentioned page 22 in your previous posts. You did mention pages 24 and 25. So, you're saying your teacher wants you to create a 3D drawing?
<<AutoCAD 2015>>
royalhorn
Newbie
Using: autocad2021
Status: Offline
Posted: 01.Sep.2021 at 13:27 |
Problem is page 22. I can't do that for ex. cows. Because of my teacher say that all figure have to in dwg.
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 01.Sep.2021 at 13:15 |
It is not our job to do your homework assignment for you. As previously stated, there are two methods one can use to replicate what needs to be drawn. Have you tried both? Where are you experiencing a problem?
<<AutoCAD 2015>>
royalhorn
Newbie
Using: autocad2021
Status: Offline
Posted: 01.Sep.2021 at 13:09 |
I didn't do that I tried for a long time but I can't. I have last 12 hours for this homework. Can u draw for me plsss. I am helpless.
philippe JOSEPH
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Posted: 28.Aug.2021 at 17:36 |
I would choose the paper option and also drawing in AutoCAD on an image can be difficult. If you choose the image option you will have to scale it at the right dimension based for example on the bigest dimension indicated.
Edited by philippe JOSEPH - 28.Aug.2021 at 18:30
