Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
RSS discussions
Discussion Discussion forum
Topic ClosedCAD 2020- LIne Mismatch
 Post Reply Post Reply
Author
efa designs View Drop Down
Newbie
Newbie
Using: cad 2020
Status: Offline
Direct Link To This Post Topic: CAD 2020- LIne Mismatch
    Posted: 02.Sep.2021 at 23:27
Thank you for your attention to this matter.
My lines are not meeting each other. They are off by 0'-0." The angles are off by decimals, i.e., .04 When I try offsetting a straight line - the perpendicular lines don't meet, and are off by 0'-0"
I tried flattening drawing, regenerating, setting my ucs, the hardware acceleration as seen on other posts and attempted changes to the snap modes, and even changed the computer.
Can anyone help me please?!
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 03.Sep.2021 at 08:19
Hello efa, are you working in 2D with lines coming from 3D exploded solids or 3D lines that maybe "rotated"?
Are all your entities at Z = 0 ?
What do you mean by "not meeting each other" : no TRIM, FILLET or CHAMFER available ?
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 06.Sep.2021 at 19:04
Off by 0'-0" is not off.  Can you explain differently?  Can you post a drawing?
Back to Top
Newbie
Newbie
Using: cad 2020
Status: Offline
Direct Link To This Post Posted: 06.Sep.2021 at 19:51
We work in 2D and drew it from scratch, so there shouldn't be 3D lines, unless we could've drawn on a 2D drawing in 3D without noticing- we work with standard 2d.
The trim, chamfer, fillet- would be if we had to cut the line- but that doesn't seem to be the problem anyway. I hope to attach a drawing on Thursday. Thanks for your time and attention to this matter.
Back to Top
Newbie
Newbie
Using: cad 2020
Status: Offline
Direct Link To This Post Posted: 06.Sep.2021 at 19:52
Thank you. I hope to post the drawing and another differing explanation on Thursday. Thanks for looking into this for us!
Back to Top
shakir.iqbal View Drop Down
Newbie
Newbie
Using: AutoCAD all versions, Revit, Tekla Structures
Status: Offline
Direct Link To This Post Posted: 07.Sep.2021 at 06:20
Type Units in AutoCAD and increase the Precision to maximum number displayed there in the drop down. Now check the Distance between the lines (using "dist" command) that you believe are not "meeting". Press F2 and copy the steps and paste here for us to understand what's going on.
Shakir Iqbal
Seasoned CAD Guru
https://www.fiverr.com/shakiriqbal482
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 08.Sep.2021 at 13:35
Did you use your OSNAPS when connecting one line to the other?  Check the setting of the ELEVATION command.  Is it set to zero?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,125 seconds.
