Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
RSS discussions
Discussion Discussion forum
Topic ClosedLayout Printing Change
 Post Reply Post Reply
Author
GPaynes View Drop Down
Newbie
Newbie
Using: Autocad 2016
Status: Offline
Direct Link To This Post Topic: Layout Printing Change
    Posted: 29.Nov.2021 at 16:55
Hi,
I have a problem with layout printing. Usually I print in 24 x 36 but sometime I print small details in 8.5 x 11 or 11 x 17. my problem is when I print details using a different printer my layout setup using a plotter for 24 x36 (which have
drawing
 title block with all the informations and scale) have been replace by the size I used for the printer details.
I looked up the web and searched some forums but couldn't find the answer for it. Is there any way when I setup a layout with all the informations to be lock no matter what I use in another printing layout? Confused
Thank you,
GPayne
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 30.Nov.2021 at 07:24
Hello GPaynes, could : ( Plot scale )  Fit to paper + Apply to Layout do the job in your plot settings ?
I know that some people doesn't like Fit to paper but if you set a paper size that shinks the margins of your little 8.5 x 11 and/or 11 x 17 inches it works fine.
My solution is to look at the Plot scale indicated when you launch a print : Scale X in. = Y unit and do a rectangle inside the real paper size in that ratio and launch the print 24 x 36 on the real big size or launch the print 8.5 x 11 on the internal paper size to keep an exact scale.
The scale will be down sized by the ratio between the paper sizes but not exactly because :
36 / 24 = 1.5   ,  11 / 8.5 = 1.29...  ,  17 / 11 = 1.54...
Ask for more
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,117 seconds.
