Discussion forum
?CAD discussions, advices, exchange of experience
New To CAD |
Post Reply
| Author | |
spartacus666
Newbie
Joined: 22.Aug.2025 Location: United Kingdom Using: autocad2018 Status: Offline Points: 3 |
Post Options
Thanks(0)
Quote Reply
Topic: New To CADPosted: 22.Aug.2025 at 09:24 |
Hi All
I am new to Autocad and I am struggling to make a simple 3d circle with a diameter of 3.5 inches and a thickness of 1 inch any help would be great
philippe JOSEPH
Senior Member
Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1538 |
Post Options
Thanks(0)
Quote Reply
Posted: 22.Aug.2025 at 10:15 |
Hello spartacus666, if you want to do some 3D solids you will have to learn a lot of 3D commands.
To elaborate a 3D solid you have to draw a closed shape, ideally an assembly of 2D entities like lines, arcs, ellipses converted into a REGION and then EXTRUDE it to the desired height. In your case I would draw a circle of radius 1.75" ( 3.5" DIA ), convert it into a REGION ( not an obligation ) and EXTRUDE it to 1". P.S. In the old versions of AutoCAD the official documentation was a big 500 pages book, then it came as a PDF file stored in your (C) disk, now what is left is the help that you get with pressing F1 on your keyboard. The problem with this is that when your press F1 you're out of AutoCAD. Eventually search the last PDF files available approx. AutoCAD 2008. Ask for more.
spartacus666
Newbie
Post Options
Thanks(0)
Quote Reply
Posted: 22.Aug.2025 at 10:31 |
Thank for the reply and the help :)
philippe JOSEPH
Senior Member
Post Options
Thanks(0)
Quote Reply
Posted: 23.Aug.2025 at 13:34 |
Hello Spartacus666, eventually see my 3D AutoCAD file : 3D_SOLIDS_01.dwg in the CAD/BIM Blocs library here in the site ( the updated one of 13.02.203 ).
It shows the main 3D commands. Ask for more.
Edited by philippe JOSEPH - 23.Aug.2025 at 13:36 |
julecave
Groupie
Joined: 17.Jul.2022 Location: Palestine Using: audocad 2015 Status: Offline Points: 86 |
Post Options
Thanks(0)
Quote Reply
Posted: 16.Dec.2025 at 14:32 |
philippe JOSEPH
Senior Member
Post Options
Thanks(0)
Quote Reply
Posted: 16.Dec.2025 at 21:07 |
Hello julecave, is it a question ?
The AutoCAD file : 3D_SOLIDS_01.dwg is the updated one, the other is older. You can find it in the CAD/BIM Blocks library here in the site.
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,105 seconds.
Topic Options
Post Options
Thanks(0)
