Discussion forum
?CAD discussions, advices, exchange of experience
Progecad Help With SLICE command |
Post Reply
| Author | |
PanamEric
Newbie
Joined: 16.Feb.2026 Location: Panama Using: Progecad 2026 Status: Offline Points: 2 |
Post Options
Thanks(0)
Quote Reply
Topic: Progecad Help With SLICE commandPosted: 27.Feb.2026 at 22:21 |
Hello, I am new to Progecad but am fairly familiar with Autocad. I started with Autocad 10 and the last version I worked with was 2017. I have been trying to use the slice command of Progecad 2026 to slice a 3D object using a circle as the slicing plane. I don't know what I am doing wrong...I can't get it to work. It works fine if I use a line as the slicing plane but it will not work with a circle. my 3D solid is a + shape with a thickness of 0.05. There are concentric circles that I am trying to use as slicing planes. I tried a simple 2D circle it lets me select it then ask me which side to keep (i chose Both) and then nothing. The command terminates I am back to command prompt and no slice was done. If I try to convert the circle to a region or solid, it wont let me select it as a slicing plane. That used to work with Autocad. What am I doing wrong? |
learned on Autocad
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,090 seconds.
Topic Options
Post Options
Thanks(0)
