Discussion forum
?CAD discussions, advices, exchange of experience
Using AI to generate geometry |
Post Reply
| Author | |
SergioR7
Newbie
Joined: 18.Jan.2026 Location: Italy Using: AutoCAD,Fusion Status: Offline Points: 5 |
Post Options
Thanks(0)
Quote Reply
Topic: Using AI to generate geometryPosted: 04.Apr.2026 at 15:33 |
I was trying the new Assistant in Fusion to create 3D models and it works quite well, although rather slow. But when I tried similar prompts in AutoCAD, its just gives me the workflow, it doesn't create geometry like in Fusion. Can I enable this somewhere?
Vladimir Michl
Senior Member
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2196 |
Post Options
Thanks(0)
Quote Reply
Posted: 04.Apr.2026 at 15:44 |
No, this behavior is "as designed". This may change in the future, but currently the Autodesk Assistant in AutoCAD 2027 can just analyze the drawing and select objects, it doesn't modify any geometry (like the AA in Fusion) - although he knows how to do that and can give you an exact script to perform the desired modifications.
See: https://www.cadforum.cz/en/examples-of-ai-prompts-and-the-challenges-of-using-ai-assistant-tip14969
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,113 seconds.
Topic Options
Post Options
Thanks(0)
