Over 1.118.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
Algee
Newbie
Joined: 08.Apr.2009 Location: United Kingdom Status: Offline Points: 1 |
Topic: Thumb nail sketch - Line StylePosted: 08.Apr.2009 at 14:28 |
Hi, I am looking for away of reproducing a line in AutoCAD so the final printed output looks like a thumb nail sketch in pencil. Has anyone any ideas to achieve this? Apart from going bsck to the drawing board!! Thank you,
Alan.
msplcdykee69
Senior Member
Joined: 15.Dec.2008 Location: United States Using: Civil 3D, Map, Inventor, Mechanical, & Electrical Status: Offline Points: 163 |
Posted: 08.Apr.2009 at 19:03 |
Here is a lisp routine I found you can try. i am not sure if this is exactly what your looking for. I hope it is. This is what it does: FREEHAND.LSP makes line and polyline objects look as if This is the lisp below:
; FREEHAND.lsp (Command function for AutoCAD) ; (c) Copyright 2001 TimeSavers for CAD ; from: www.timesaversforcad.com ;----------------------------------------------------------------------------------- ; Description: ; ; Modifies lines and polylines to appear as if drawn freehand. ; Two things occur: ; 1. Corners are given slight overlap. ; 2. Lines are given slight "wiggle" to them. ; User can specify degree of both overlap & wiggle [1 small - 5 large, 0-none] ; Accomplished by first lengthening each line, then replacing line ; with LWPOLYLINE(R14) or POLYLINE(<R14) and adding slightly offset vertices. ; ; Globals: fh_scal(freehand scale), fh_oscl (overlap scale), fh_wscl (wiggle scale) ;=================================================================================== (alert "\nChanges made by FREEHAND cannot \nbe restored once you leave drawing.") (defun c:freehand (/ *fh:err* o_m c_e fh_s fh_os fh_ws x ss ssp e ed llc p1 p2 d el ne
vertno ang vertd offd offang vlst elst lp dsf) ;-ERROR HANDLING (defun *fh:err* (m) (or (member m '("Function cancelled" "quit / exit abort" "console break")) (prompt (strcat "\n< " m " >\n")) ) (setvar "osmode" o_m)(setvar "cmdecho" c_e) (setq *error* *e*)(princ) ) ;-GET VALUES/SETUP
(setq *e* (cond (*e*)(*error*)) *error* *fh:err* c_e (getvar "cmdecho") o_m (getvar "osmode") dsf (getvar "dimscale") ;TSC (scale) ) (setvar "cmdecho" 0) (command "undo" "e" "undo" "g") (setvar "osmode" 0) (or (= (type fh_scl) 'REAL)(setq fh_scl 1.0)) (or (= (type fh_oscl) 'INT)(setq fh_oscl 3)) (or (= (type fh_wscl) 'INT)(setq fh_wscl 3)) ;-GET FREEHAND SCALE FACTOR
(if (setq fh_s (getreal (strcat "\nFreehand Scale <" (rtos fh_scl 2) ">: "))) (setq fh_scl fh_s) ) ;-GET AMOUNT OF OVERLAP
(initget "0 1 2 3 4 5") (if (setq fh_os (getint (strcat "\nLine OVERLAP amount [1 small-5 large, 0 none] <"(itoa fh_oscl)">: "))) (setq fh_oscl fh_os) ) (cond ((= fh_oscl 0)(setq fh_os nil)) ((= fh_oscl 1)(setq fh_os 0.2)) ((= fh_oscl 2)(setq fh_os 0.7)) ((= fh_oscl 3)(setq fh_os 1.2)) ((= fh_oscl 4)(setq fh_os 1.7)) ((= fh_oscl 5)(setq fh_os 2.2)) ) (initget "0 1 2 3 4 5") ;-GET AMOUNT OF WIGGLE
(if (setq fh_ws (getint (strcat "\nLine WIGGLE amount [1 small-5 large, 0 none] <"(itoa fh_wscl)">: "))) (setq fh_wscl fh_ws) ) (cond ((= fh_wscl 0)(setq fh_ws nil)) ((= fh_wscl 1)(setq fh_ws 0.02)) ((= fh_wscl 2)(setq fh_ws 0.07)) ((= fh_wscl 3)(setq fh_ws 0.12)) ((= fh_wscl 4)(setq fh_ws 0.17)) ((= fh_wscl 5)(setq fh_ws 0.22)) ) ;-SELECT OBJECTS
(if (setq ss (ssget '((-4 . "<OR")(0 . "LINE")(0 . "LWPOLYLINE")(0 . "POLYLINE")(-4 . "OR>")))) (progn (prompt "\nFREEHAND in progress...") (if (setq ssp (ssget "P" '((-4 . "<NOT")(0 . "LINE")(-4 . "NOT>")))) (progn (setq el (entlast) x 0) (while (setq ne el el (entnext el))) (while (< x (sslength ssp)) (ssdel (setq e (ssname ssp x)) ss) (command ".explode" e) (setq x (1+ x)) ) (while (setq ne (entnext ne))(ssadd ne ss)) ) ) (setq x 0) (while (< x (sslength ss)) (setq e (ssname ss x) ed (entget e)) ;-GET NEEDED INFO FROM LINE (setq llc (list (assoc 8 ed)) ;start Layer/Ltype/Color list p1 (cdr (assoc 10 ed)) p2 (cdr (assoc 11 ed)) ang (angle p1 p2) d (distance p1 p2) ) (if (assoc 6 ed)(setq llc (cons (assoc 6 ed) llc))) (if (assoc 62 ed)(setq llc (cons (assoc 62 ed) llc))) ;-CREATE OVERLAP (if (and fh_os (> d 0)) (progn ;*-overlap distance, adjust # after "dsf" - larger=less (setq ovlpd (+ (* (/ dsf 160) fh_scl)(* fh_os fh_scl)) p1 (polar p1 ang (- ovlpd)) p2 (polar p2 ang ovlpd) ) (setq ed (subst (cons 10 p1)(assoc 10 ed) ed) ed (subst (cons 11 p2)(assoc 11 ed) ed) ) (entmod ed) (setq d (distance p1 p2)) ) ) ;-CREATE WIGGLE (if (and fh_ws (> d 0)) (progn (setq vlst nil lp p1 ;*-number of vertices, adjust # after "dsf" -larger=more vertno (fix (/ d (+ (* (/ dsf 16) fh_scl)(* 3 fh_scl)))) ;;;(+ (* (/ dsf 16) fh_scl) 3))) vertd (if (> vertno 0)(/ d (1+ vertno))) ;*-offset distance for vertices, adjust # after "dsf" -larger=less offd (+ (* (/ dsf 480) fh_scl)(* fh_ws fh_scl)) offang (+ ang (/ pi 2)) ) ;-MAKE LIST OF VERTICES FOR NEW PLINE (repeat vertno (setq lp (polar lp ang vertd) vlst (cons (polar lp offang offd) vlst) offang (+ offang pi) ) ) ;-DELETE LINE (entdel e)(setq e nil) (if (= (substr (getvar "acadver") 1 2) "14") (progn (setq elst (list (cons 10 p2)'(40 . 0.0)'(41 . 0.0)'(42 . 0.0))) (foreach v vlst (setq elst (append (list (cons 10 v)'(40 . 0.0)'(41 . 0.0)'(42 . 0.0)) elst)) ) (setq elst (append (list (cons 10 p1)'(40 . 0.0)'(41 . 0.0)'(42 . 0.0)) elst)) (entmake (append '((0 . "LWPOLYLINE")(100 . "AcDbEntity")) llc (list '(100 . "AcDbPolyline") (cons 90 (/ (length elst) 4)) '(70 . 0) ) elst )) ) (progn ;-REPLACE WITH PLINE (entmake (append '((0 . "POLYLINE")(70 . 128)(66 . 1)) llc)) (entmake (append (list '(0 . "VERTEX")(cons 10 p2)) llc)) (foreach n vlst (entmake (append (list '(0 . "VERTEX")(cons 10 n)) llc))) (entmake (append (list '(0 . "VERTEX")(cons 10 p1)) llc)) (entmake (cons '(0 . "SEQEND") llc)) ) ) ) ) (setq x (1+ x)) ) (command "undo" "e") (prompt "\nFreehand complete. ") ) ) ;-RETURN VALUES
(setvar "osmode" o_m)(setvar "cmdecho" c_e) (setq *error* *e*) (princ) ) ;-END FILE |
Engineering Manufacturing Medical Cables/Adjunct Instructor Engineering Graphics/Engineering Computations and Careers
msplcdykee69@yahoo.com Shawn |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,293 seconds.
Topic Options
