Over 1.133.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
LTunlimited RSS
RSS robots
Topic: Viewports Zoom Extents When ActivatedPosted: 23.Nov.2009 at 14:50 |
This is another post inspired by a frequent discussion-group topic. The scenario is that someone double-clicks inside an unlocked viewport and suddenly the view zooms to extents. Probably not what you had in mind.Like a lot of unexpected behaviors in AutoCAD LT, the fix is easy once you know where to look. In this case, it's the variable UCSFOLLOW. When it's set to 0, as it is by default, nothing happens to your view when you change the UCS -- i.e. when you go from layout coordinates to model space. But if it gets set to 1, a change in UCS automatically regenerates a plan view, and zooms to the extents of the drawing.The only thing to remember is that each viewport has its own UCSFOLLOW setting. So if you have more than one viewport acting up, you need to set USCFOLLOW to 0 in each viewport. (That means double-click inside it and change the variable. Changing it in just model space or just a layout isn't enough.)Locking a viewport also prevents this kind of view changes -- depending on your setup, that may be a viable alternative too.
Go to the original post... |
LT Unlimited - Autodesk blog by Kate Morrical
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,145 seconds.
Topic Options
