Over 1.130.000 registered users (EN+CZ).
The new Beam calculator, Tolerances, Spirograph generator and Regression curves in the Converters section.
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
sudath
Newbie
Joined: 28.Dec.2009 Location: Sri Lanka Status: Offline Points: 7 |
Topic: Solid SpiralPosted: 09.Feb.2010 at 14:12 |
How can I draw a solid spiral?
tulip3D
Senior Member
Joined: 23.Jul.2009 Location: United States Using: AutoCAD2011, Inventor2011 Status: Offline Points: 427 |
Posted: 09.Feb.2010 at 15:53 |
Well, using inventor, create two sketches, one following your spiral or the direction of it, the other showing the profile. Then hit sweep, select the profile, then the direction. Bang! Spiral.
sudath
Newbie
Posted: 10.Feb.2010 at 04:48 |
Thank you, but I meant using Auto-cad.
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2182 |
Posted: 10.Feb.2010 at 07:43 |
Please post your questions in the right forum - for AutoCAD-related questions there is the "AutoCAD" forum.
To answer your question - there is the "Related CAD tip" #836 - just below the postings.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
sudath
Newbie
Posted: 10.Feb.2010 at 07:58 |
I apologize for the mistake and thank for the advises.
Goldenbogic
Newbie
Joined: 11.Feb.2010 Location: Saudi Arabia Status: Offline Points: 2 |
Posted: 11.Feb.2010 at 15:17 |
you can draw a solid spiral by drawing helix and modifying it and sweep command, to draw helix just write helix in command line, everything will follow...
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,105 seconds.
Solid Spiral
Topic Options
