Discussion forum
CAD discussion |
Copy everything within a circle or square. |
Post Reply |
Author | |
Jordan Wies
Newbie Joined: 07.Jan.2008 Location: United States Status: Offline Points: 1 |
Topic: Copy everything within a circle or square. Posted: 07.Jan.2008 at 00:16 |
Hello, I'm new here.
I'm trying to figure out a way to place a circle somewhere in a drawing, and then copy the circle, plus anything that resides inside the circle, without having to trim the objects around the circle.
this would be used for making a "blown-up" view of detailed areas of a drawing, so I can copy a small part of that area, scale it to something bigger, and place leaders and text to explain the details.
Thank you!
-J
The optomist says the glass is half full, the pessimist says the glass is half empty, the engineer says the glass is twice as big as it needs to be.
Vladimir Michl
Posted: 07.Jan.2008 at 09:47 |
You can try the EXTRIM command from Express Tools.
Vladimir Michl (moderator)
JJ@MIMS
Newbie Joined: 06.Dec.2007 Status: Offline Points: 6 |
Posted: 10.Jan.2008 at 18:06 |
you can make a round view port in paper space or make a view port with an object.
caddy
Newbie Joined: 13.Jan.2008 Location: Italy Status: Offline Points: 1 |
Posted: 13.Jan.2008 at 07:34 |
Best solution, use Extrim command. After, use Copy command and type in IP on command line. Disable OSNAP and costruct a polygon around circle. Now copy polygon and paste it on a new autocad file. Close but don't save your source file. Open it again and paste your previous polygon and adjust it.
--caddy |
Post Reply | |
Tweet
This page was generated in 0,375 seconds.
