Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
vafranco
Newbie
Joined: 26.Sep.2010 Location: United States Using: 3ds Max Design, AutoCAD2011 Status: Offline Points: 2 |
Topic: Cant render!!Posted: 27.Sep.2010 at 00:01 |
I imported a 2d file from autocad into 3ds and not i can't render it... help!!!
Cad64
Senior Member
Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 27.Sep.2010 at 01:29 |
Well of course you can't render it. If it's a 2D file there is nothing to render. It's just lines. In order to render, you need 3D models, not 2D linework.
Online Portfolio: http://www.rdeweese.com/
vafranco
Newbie
Posted: 27.Sep.2010 at 01:35 |
I extruded it and modeled it. its not just linework though.
Cad64
Senior Member
Posted: 27.Sep.2010 at 01:59 |
Ok, but you didn't say that though. You said you imported and 2D Autocad file and you can't render it. When asking for help, it's good to provide as much information as possible, so we can help you without having to ask 20 questions.
So, when you render, what happens? Do you get an error message? Does your render come out blank, with no model showing up? Have you applied textures? Have you set up lights? Have you set up a camera? What version of Studio Max are you using? What rendering engine are you using, (Mental Ray, Vray, Default Scanline, Other)? The more information you provide, the easier it will be for us to help you get to the bottom of this problem. |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,066 seconds.
Cant render!!
Topic Options
