RSS discussions
Discussion Discussion forum
Topic ClosedSketch causes autodesk to crash
 Post Reply Post Reply
Author
lemiant View Drop Down
Newbie
Newbie
Using: Inventor2011
Status: Offline
Direct Link To This Post Topic: Sketch causes autodesk to crash
    Posted: 23.Jan.2011 at 22:09
Hi everyone,
I am quite new to Autodesk Inventor 2011. I have been making parts, and doing tutorials for the past week, and Inventor has been perfectly stable. However, finishing a specific sketch has become impossible, because every time I try to add a specific constraint, it crashes. I have posted the file at:
http://host.codingproject.net/Lift.ipt
I have added a couple of things, to help you find the error: There is a line sticking out of the rectangle; If you follow the line into the rectangle, it ends at a point. That point is in between two triangles. And if you try to add a dimension from the right side of the left triangle to the left side of the right triangle, Inventor crashes.
Does anyone know how this could be fixed?
Thanks,
Lemiant
Edited by lemiant - 23.Jan.2011 at 23:26
Back to Top
Quagga View Drop Down
Newbie
Newbie
Using: autocad 2012, inventor 2012, solidworks 2011
Status: Offline
Direct Link To This Post Posted: 28.Jan.2011 at 23:00
I opened your part and aadded a dim of 0.25 between the two lines without any crash.
Have you got all the latest service packs and hotfixes installed?
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,188 seconds.
