CZ | EN | DE
Login or
registration
  Visitors: 4604
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedPDF to DWG converter
 Post Reply Post Reply
Author
markjohnsonii View Drop Down
Newbie
Newbie
Using: Autocad
Status: Offline
Direct Link To This Post Topic: PDF to DWG converter
    Posted: 07.Feb.2011 at 14:58
Hey everyone, I was hoping for some help:
I have some 2D floor plans and mechanical PDFs that I need to convert to DWGs so I can edit them.
Is there a reliable PDF - to - DWG converter out there that works?
Thanks!!!
Back to Top
Kajito View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 07.Feb.2011 at 15:07
there are many tools, but the truth is that, if the pdf is just an image, nothing will help you to get dwg that you could edit (unless u will use some superproffesional software). If the pdf was created from autocad, it is a different story. I tried progecad (trial version) and this software is able to convert this kind of pdf to dwg pretty well. (progecad is simmilar to autocad, but autocad doesn't have this function).
that is my experience.
Back to Top
Newbie
Newbie
Using: Autocad
Status: Offline
Direct Link To This Post Posted: 07.Feb.2011 at 15:14
I'll download the progecad and see if it can convert it.  yes, these PDF's were made from an Autocad dwg.
Thanks!
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 07.Feb.2011 at 15:18
If the drawings were originally done in AutoCAD ask the person who did them to email you a copy and save the headaches of trying to convert the PDFs.  You're not using the PDFs to avoid asking for the DWG files are you?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad
Status: Offline
Direct Link To This Post Posted: 07.Feb.2011 at 15:22
No, I work at a college and a lot of our old digital plans are all PDFs.  I am trying to start a project and getting these PDFs into DWGs will reduce my project time immensely!
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 07.Feb.2011 at 17:26
one more thing that might help. As the origin of the PDF is from Autocad, if u r using latest autocad, u can insert the pdf into model space and u'll have the option of snapping, so that u can easy trace the pdf if needed.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 07.Feb.2011 at 18:47
Use PDFATTACH.  Then use the SCALE command and the REFERENCE option.  Basically trace the drawing over.  Cost?  Your time and whatever you bill at.  Result?  You get the drawing set up the way you want re; layers, linetypes, colors, text styles, etc.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,525 seconds.
