Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
capnkurf
Newbie
Joined: 29.Jan.2011 Location: United States Using: Autocad 2007 Status: Offline Points: 5 |
Topic: inserting a picture filePosted: 08.Feb.2011 at 05:47 |
Is there a way to insert a jpeg image in to your drawing file to be included in your layout, along with drawings, to be viewed and plotted ?
Vladimir Michl
Moderator Group
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2188 |
Posted: 08.Feb.2011 at 08:33 |
yes, there are several ways to do this - see e.g. the tips 871 and 7678
Vladimir Michl (moderator)
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 08.Feb.2011 at 12:07 |
Try the IMAGEATTACH command. It's use is covered in your AutoCAD Help files.
<<AutoCAD 2015>> |
HAWDesigner
Senior Member
Joined: 04.Aug.2008 Location: United States Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010 Status: Offline Points: 310 |
Posted: 08.Feb.2011 at 15:35 |
Remember, there are differences between the various methods of "inserting an image". Some merely LINK to the image, others actually insert the image itself into the DWG.
Refer to this post for those differences: http://www.cadforum.cz/forum_en/forum_posts.asp?TID=5230&KW=&PID=13013#13013 Good Luck capn!! |
R. Williams AutoCAD 2010 Certified Professional <!-- If all else fails hit F1 --> <<AutoCAD 2009 |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,121 seconds.
Topic Options
