RSS discussions
Discussion Discussion forum
Topic ClosedCopy Named Objects from Xrefs
 Post Reply Post Reply
Author
LTunlimited RSS View Drop Down
RSS robots
RSS robots
Status: Offline
Direct Link To This Post Topic: Copy Named Objects from Xrefs
    Posted: 16.Jun.2011 at 10:11
AutoCAD LT 2012 introduced the NCOPY command, which lets you bring objects from referenced files into the host drawing. But what if you just want to grab a dimension style (not a dimension object) from an xref? Try a much older command: XBIND! XBIND (which is not the same as BIND) is most easily available at the command line. It lets you import named objects—layers, dimensions styles, text styles, blocks, linetypes—from a referenced DWG into the current file. Bound items bring in their drawing prefix; the layer imported above would become “MapBuildings$0$_EDIFICIOS”. If you want to get rid of that, you can always use the RENAME command.
Go to the original post...
LT Unlimited - Autodesk blog by Kate Morrical
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,094 seconds.
