Over 1.133.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
LTunlimited RSS
RSS robots
Topic: Mask Multiline TextPosted: 17.Jan.2012 at 11:11 |
After last week’s post on background masks for dimension objects, I poked around through my archives and realized I’ve never posted on regular text masks. I know I put it in a demo video, but I guess it never got its own post. Let’s fix that. When you’re creating or editing multiline text, there’s a button the Formatting panel called Background Mask. Click on it, and you’ll get a dialog box where you can set the offset factor and the fill color. The offset factor, how far the mask extends beyond the text, is relative to the text height. A factor of 1 keeps the mask the same size as the text. A factor of 1.5 provides a border equal to half the text height all the way around. The maximum factor for the mask is 5.0. For the fill color, you can either pick a standard color, or use the background color of the drawing, which basically means it’ll plot clear. New in 2012, the values you choose when creating a mask for a *new* text object will be remembered for the next time you want to apply a mask. (Previously, they defaulted to 1.5 and red every time.) The reason this only works for new text objects is that background masks are a property of the text. See?  So you have to actively set the variables for a new object before they’ll persist. Â
Go to the original post... |
LT Unlimited - Autodesk blog by Kate Morrical
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,160 seconds.
Mask Multiline Text
Topic Options
