RSS discussions
Discussion Discussion forum
Topic ClosedSTL to Solid for inventor
 Post Reply Post Reply
Author
JakeD View Drop Down
Newbie
Newbie
Using: Inventor
Status: Offline
Direct Link To This Post Topic: STL to Solid for inventor
    Posted: 22.Aug.2012 at 23:21
Hi there, my name is Jake im new to this.
I currently have a stl file that was made on solid edge (not by me) but I want to be able to edit it on inventor, I have been able to load it into inventor but i cannot edit the file due to it still being in a mesh state <if that's the right way to describe it
I would like to be able to have it in ipt format
Is there anyway this can be done? I have searched on the internet for many hours with no luck, any insight to this would be very much appreciated
Thanks
Jake
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 23.Aug.2012 at 08:24
You can save the mesh to IPT. If you need a solid object you may be able (depending on the mesh geometry) to stitch the mesh to a solid.
Vladimir Michl (moderator)
Back to Top
Newbie
Newbie
Using: Inventor
Status: Offline
Direct Link To This Post Posted: 23.Aug.2012 at 09:19
Thank you for replying,  I have just tried this but when I go to select the mesh nothing happens,
is there any other way to do this?
Thanks
Jake
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,075 seconds.
