Please abide by the
rules of this forum.
large rectangular pattern
Author
Topic Search Topic Options
formogfrys
Newbie
Using: acad 10 inventor 10
Status: Offline
Topic: large rectangular pattern Posted: 08.Aug.2013 at 08:24
inventor 2010 problem
when i use many pettern in the rectangular pattern my pc goes down, is there any god ideas?
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 08.Aug.2013 at 11:39
Could it be a corrupt drawing? What are the specs on your computer?
"Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance." <<AutoCAD 2015>>
formogfrys
Newbie
Status: Offline
Posted: 08.Aug.2013 at 11:52
John Connor wrote: Could it be a corrupt drawing? What are the specs on your computer?
it is on all the computers, some time it dont goes down, but only get extreamly slow.
I think that the computer is too slow to calculate, but also on the "big" computer is there problems.
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 08.Aug.2013 at 14:37
What is the file size? What are the specs of the "big" computer?
formogfrys
Newbie
Status: Offline
Posted: 08.Aug.2013 at 15:11
John Connor wrote: What is the file size? What are the specs of the "big" computer?
file size is about 10000 kb
pc:
Win7 Pro 64Bit
Intel xeon E5 1950
8GB 3,2 Ghz
NVIDIA QUA 2000
ianitski
Newbie
Using: turbo cad
Status: Offline
Posted: 13.Sep.2013 at 22:03
Would try to create a series of patterns instead of just one if the pattern is quite large
Pc should be able to process it faster
For example Top to Bottom then left to right
Forum Jump
-- Select Forum --
-CAD Forum- (read-only)
AutoCAD
Inventor
Revit
Civil 3D, Map, InfraWorks
Fusion 360
3ds Max, Maya, VRED
CAD - general
ARKANCE (CAD Studio) applications
RSS Feeds
Technical support by ARKANCE
Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum
This page was generated in 0,063 seconds.
