RSS discussions
Discussion Discussion forum
Topic ClosedEdit Blocks to Multiple Sheets
 Post Reply Post Reply
Author
aisoos View Drop Down
Newbie
Newbie
Using: AutoCAD2010, AutoCAD2011, AutoCAD2012, AutoCAD2013
Status: Offline
Direct Link To This Post Topic: Edit Blocks to Multiple Sheets
    Posted: 09.Aug.2013 at 21:22
Hi everyone,
Im trying to find out if theres a way to edit a block once and would be change for all the sheets.
Reason is im trying to revise a titleblock that an architect sent us.. and apparently instead of using xref for the TB they used actuall blocks.. so I have to bedit change a # and save.. and i have to do this on all the sheets..
I'm wondering now if there's a way i could do a change one time and thats it.
Thanks
"If You're Dreams Do Not Scare You, They're Not Big Enough"
-Ellen Johnson Sirleaf
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 11.Aug.2013 at 05:09
You may have found this out already, but if all the sheet blocks are in the same file the answer is YES.  You can make a change to the block and it will automatically affect all the blocks in the drawing as soon as you resave the block.
But if these title blocks are in different drawings you'll have more work to do.  You may be able to make tool palettes help you.  But a lot will depend on what data is being placed in the block, and how.
Dave
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,105 seconds.
