Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
Welladjstd
Newbie
Joined: 30.Aug.2013 Location: United States Using: sketchup Status: Offline Points: 3 |
Topic: solidworks 2013Posted: 21.Sep.2013 at 06:09 |
I have created a part in solidworks and it is only 335 exported as an stl file.. I had the same part scanned and the stl file they sent me was 11.7mb. What am I doing wrong. I don't have enough data in my model to generate a gcode that will generate my part. I am new to this and would like some help. Thanks
Welladjstd
Newbie
the last part was 335 kb
John_victor
Newbie
Joined: 07.Aug.2013 Location: United States Using: AutoCAD2013 Status: Offline Points: 5 |
Posted: 27.Sep.2013 at 14:42 |
I think you've some exporting problems so Select either Binary or ASCII as the file format. To set the STL export options: 1. Click File, Save As. 2. Select STL (*.stl) for Save as type, then click Options. 3. Select from the options described below, then click OK. 4. Click Save to export the document. -Select either Binary or ASCII as the file format. Binary files are smaller than ASCII files, but they are not supported in some other systems. Select the type supported by the target system. -Unit. Select the unit of measure. - Show STL info before file saving. Displays a SolidWorks dialog box (when you click Save in the Save As dialog box) that contains the following information: Triangles (number), File Size, File Format, and the directory path and file name. Edited by John_victor - 27.Sep.2013 at 14:44 |
Quick 2D to 3D conversion services from
IndiaCADworks |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,086 seconds.
solidworks 2013
Topic Options
