RSS discussions
Discussion Discussion forum
Topic ClosedDelete key not working
 Post Reply Post Reply
Author
sebw666 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Delete key not working
    Posted: 29.Oct.2013 at 19:34
Recently Installed AutoCAD 2013 on 2 laptops. On one laptop the delete key is not working. I have checked the PICKFIRST command and set this to 1 and also checked the graphics card and keyboard hot keys! The delete key is still not working! Does anybody have any another suggestions?
Thankyou in advance
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 29.Oct.2013 at 22:41
Did you shut the computer down then reboot it?  Sometimes that's all it takes.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 30.Oct.2013 at 10:24
Thankyou for the reply.
Yes I rebooted a couple of times. Also performed a software repair and re-install still to no avail. Finally discovered it was a keyboard issue. Basically when the 'Num Lock' is activated the 'Delete' key doesn't work! When the 'Num Lock' is off the 'Delete' key works. Very very strange, the laptop is only 2 days old........its still annoying but I'll put up with it. I should also say, in all other software both keys work fine and in tandem.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 30.Oct.2013 at 10:33
I'll never understand why people think uninstalling software is the way to fix a hardware issue.  Kind of like replacing the motor in a car because a tire went flat (extreme and pointless).
Well you figured it out so I guess that's what counts most.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,180 seconds.
