RSS discussions
Discussion Discussion forum
Topic Closedcreating lines in angle
 Post Reply Post Reply
Author
Heinmor View Drop Down
Newbie
Newbie
Using: draftsight
Status: Offline
Direct Link To This Post Topic: creating lines in angle
    Posted: 18.Nov.2013 at 23:06
Hay,
I am new on this forum.
I am using Draftsight and I like to create a line in a specific angle but I don't know how to do that.
thanks fo helping me.
heinmor
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 19.Nov.2013 at 00:29
Are you familiar with a technique called "direct distance entry"?  It's but one method available to you.
Let's say you want to draw a line 150 units long at an angle of 32 degrees.  This is what you would enter at the command line after invoking the LINE command:
@150<32
Try it.
Edited by John Connor - 19.Nov.2013 at 00:35
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: draftsight
Status: Offline
Direct Link To This Post Posted: 19.Nov.2013 at 01:10
Thanks, its working!Big smile
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 19.Nov.2013 at 12:29
Another option for you.  Invoke the SNAPANG command and type in a new angle for your crosshairs.  Try it and see what happens.  Use an angle of 45.
One more...try using Polar guides.  In the Settings option the user can add to the default angles that AutoCAD would use.  Can't give you much more detail about the feature as I don't make use of it.
BTW...you're not going to find many DraftSight users at this forum.  I think I'm the only one who shows up on a regular basis here.  You might have better luck getting answers to your questions in the future at the DraftSight forum.  Just a suggestion.
Edited by John Connor - 19.Nov.2013 at 13:39
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,234 seconds.
