Over 1.104.000 registered users (EN+CZ).
New AutoCAD 2026 commands and sys.variables and env.variables,.
    Discussion forum
 Discussion forum
 ?CAD discussions, advices, exchange of experience
 | AutoCAD drawing texts to Excel |
| Post Reply   |
| Author | |
| MHDhokai   Newbie   Joined: 21.Nov.2024 Location: India Using: AutoCAD2023 Status: Offline Points: 2 |  Post Options  Thanks(0)  Quote  Reply  Topic: AutoCAD drawing texts to Excel Posted: 21.Nov.2024 at 16:36 |
   Hello all, Can anyone guide me through a lisp which could work similar with Autocad Text as well as Attributes to the below tip CAD Forum - How to export AutoCAD drawing texts to Excel? Actually, I'm facing VLAX-CREATE-OBJECT issue with Autocad LT. So, I'm not able to use that one. Thanks in advance for the help... | |
| Vladimir Michl   Moderator Group   Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2143 |  Post Options  Thanks(1)  Quote  Reply  Posted: 21.Nov.2024 at 18:07 |
   Hello, we have modified the Txt2XLS utility - it will fallback to generate a CSV file in LT, where Excel is not available.
     Vladimir Michl (moderator) ARKANCE - https://arkance.world - Autodesk Platinum Partner | |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,156 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
  Topic Options
 Topic Options
