CAD tip # 11479:
Tip 13683: | Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for |
Tip 8482: | How to convert CUI file to MNU or CUIX to CUI? |
Tip 7896: | AutoCAD displays an empty ribbon only. |
Tip 7604: | How to decompile a CUIX menu file? |
Tip 4277: | What are the .CUI files? |
Quickly repeat last command in Fusion 360 (like Enter in AutoCAD) « | » Why you should not use the DEFPOINTS layer to draw geometry?
Featuring: Increase your productivity with our set of BIM add-on functions for Autodesk Revit CADstudio Revit Tools ![]() |
