  Visitors: 5250
CAD tip CAD tip # 11469:
Why you should not use the DEFPOINTS layer to draw geometry?
A - answer In historical versions of AutoCAD, the system layer for automatic auxiliar dimension points - DEFPOINTS - have been used to draw construction geometry in DWGs. The default property of this layer was used in this -- as this layer is not plotted.
But such "misuse" of the DEFPOINTS layer is to be avoided. The standard "Plot" flag is now available at all user-defined layers - and - AutoCAD expects that the DEFPOINTS layer contains really only its own auxiliar dimensioning control points and it approaches the content of this layer in a special way. This may cause problems when such DWG file is processed later - especially by other users.
Compare e.g. the behaviour of object selection in the DEFPOPINTS layer when a standard layer is frozen and when the layer 0 is frozen - suddenly, the objects cannot be selected:
If you e.g. place a viewport object to the DEFPOINTS layer and freeze the layer 0, you won't be able anymore to set a fixed scale to that viewport.
The DEFPOINTS layer behaves in a similar way when you just switch off the layer 0. And when you add possible combinations with objects embedded in blocks, groups and paperspace, using the DEFPOINTS layer can be a source of unneccessary complications.
The DEFPOINTS layer also does not respect the point display style (PDMODE/PDSIZE).
The improper use is also indicated by AutoCAD's AUDIT command - if it locates any objects drawn in the DEFPOINTS layer, it moves them as an error to the logging layer $AUDIT-BAD-LAYER (making them plottable again, by the way).
So avoid drawing user objects to the DEFPOINTS layer. If you don't want to plot an object, put it in a layer with the "Plot" flag disabled.
ACADLT
9.6.2017    12450×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 12705:How to disable osnaps for xref objects?
Tip 9153:Arrowheads or other parts of dimensions are not printed.
Tip 9090:Why are suppressed table borders still displayed?
Tip 7565:Where from comes the layer $AUDIT-BAD-LAYER ?
Tip 6920:How to add a suffix or prefix to all layers.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
