  Visitors: 12195
CAD tip CAD tip # 10091:
Adding polyline vertices in fixed intervals.
A - answer Using the VTXdist utility you can automatically add vertices (vertex) to a selected polyline - in fixed-length intervals or in a given number of regular segments (along its length). This is a kind of grip-based DIVIDE/MEASURE (without breaking the polyline). See an example of the original and enhanced curves (grip-selected) with vertices added in 4 segments:
Download the LISP application VTXdist from Download, load it with APPLOAD and run the VTXDIST command. Specify the fixed length of the interval (station segment), or "N" to enter the number of regularly spread segments along the whole polyline length. The application supports only lighweight 2D polylines (LWPOLYLINE) and sections (SECTION).
ACAD
10.11.2014    20678×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 12479:PkLength - export line lenghts to Excel.
Tip 9743:How to use XY coordinates from Excel as polyline vertices in AutoCAD?
Tip 9185:Fix problem of Areas on self-intersecting curves in AutoCAD 2013.
Tip 9042:Random scatter of AutoCAD drawing objects - SCATTER.
Tip 7099:Blocks perpendicular to a polyline.
