  Visitors: 10382
CAD tip CAD tip # 7099:
Blocks perpendicular to a polyline.
A - answer I want to draw (insert) a series of blocks along a polyline. But they should not be aligned to the polyline like in the MEASURE / DIVIDE commands but rather perpendicular to the current direction of the polyline.
This is the same method of aligning blocks. Just redefine your block (or a copy of it) and rotate it 90 degrees - use REFEDIT or BEDIT and ROTATE all the entities of your block 90 degrees around its reference point. Save the redefined block and repeat the MEASURE / DIVIDE command with the options Block and Align. The same approach can be used for the VerticesBlk utility.
Thanks CarlB for the original concept
ACAD
10.12.2009    11853×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 9265:RENAME on steroids - complex renaming of AutoCAD objects.
Tip 8852:Publish interactive 3D models on the web with Autodesk 360.
Tip 8837:MText justification does not hold.
Tip 8479:How to generate 3D surface with a mathematic expression?
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
