Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 11565:
Question
Using the freeware utility AttDefault you can reset all or just a selected attribute(s) of a block reference (insert) to the original default value, as preset in the block definition (originally offered on the block insertion).
Download the AttDefault add-on application from DL Download, load it with APPLOAD and then type the command ATTDEFAULT (to reset the whole block reference) or ATTDEFAULT1 (to reset just a single, picked attribute).
If the attribute definition contains a default value specified with a simple dynamic text field, the text field will be restored in the picked block reference. If the attribute definition contains no default value, the attribute contents is cleared (set to an empty string "").
ACAD
16.8.2017    10769×
Share the tip:
applies to: AutoCAD ·
Tip 14537:Automation of AutoCAD drawing texts using fields.
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 14402:What is the difference between the BLOCKREPLACE, BREPLACE, REPLACEBLOCK, RIBLOCK and BLKREDEF commands?
Tip 14386:Visual catalog of blocks defined in a DWG drawing.
Tip 14361:Extended ATTOUT/ATTIN for block attribute management in Excel (also for LT).
Back    All CAD Tips
Categ:
