  Visitors: 7994
CAD tip CAD tip # 8327:
CHM help: Navigation to the webpage was cancelled.
A - answer After you download a CHM help file for a software application or add-on module, this help cannot be opened. After you launch (view) it, the help window will be opened but it is empty and displays only the "i" icon and the error message "Navigation to the webpage was cancelled."
This blank content is caused by a Windows system protection of documents downloaded from the internet (from a non-local zone). Right-click on the downloaded .CHM help file, choose Properties from the context menu and in the Properties dialog (the General tab) click on the "Unblock" button at the bottom. The CHM file will then open as it should.
ACADCivilInventorRevit
100% Win7,Vista  CAD
16.11.2011    5707×
applies to: AutoCAD · Civil 3D · Inventor · Revit ·
Tip 13809:AutoCAD displays continuous lines and texts as dotted.
Tip 13760:Parametric text content in Fusion 360 sketches (and models).
Tip 13735:My initial login to Fusion 360 isn't working.
Tip 13582:My Fusion 360 stays in offline mode and cannot be switched online.
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
