Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 10010:
Question
If you use the shortcut for making a new copy of an existing layout by mouse-dragging it with Ctrl, this layout duplication procedure doesn't work in an installed version of AutoCAD 2015. You need to install Service Pack 2.
See DL Download
ACAD2015ACLT2015
18.9.2014    13443×
Share the tip:
applies to: AutoCAD 2015 · AutoCAD LT 2015 ·
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 13933:How to set grid colors in AutoCAD Web?
Tip 12210:How to erase a specific object type in all DWG layouts?
Tip 11967:How to apply a changed drawing template (DWT) to existing drawings?
Tip 11794:Undocumented code in field expression - MText contents without control characters.
Back    All CAD Tips
Categ:
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2015 More info
