Over 1.092.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 7776:
Question
For a quick overview of the repeat frequency of texts in your drawing and for a quick spotting of duplicate texts you can use the free utility CADstudio TextFreq.
Download
After you load it (_APPLOAD) and start the TEXTFREQ command, select the text objects (or All) and the function displays a table with the number of occurrences of each text string (descending by number, split duplicate/unique) - e.g.:
Command: TEXTFREQ Select texts to analyze: Select objects: 19 selected Total 19 texts selected Text frequency analysis of 8 unique texts (descending): -------------------------------------------------------- repeating - the mother of wisdom 11 hello .......................... 2 --------------------------------------- alphabet ....................... 1 beta ........................... 1 beta1 .......................... 1 Mary had a little lamb\Pwhose fl 1 mylabel......................... 1 This drawing cannot be copied wi 1 --------------------------------------- (duplicate texts are highlighted)You can download the TextFreq add-on application from
ACAD
7.2.2011
12914×
applies to: AutoCAD ·
