Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 7779:
Question
To stop the "Unreconciled New Layers" error messages, you can set either of the following system variables to 0.
LAYEREVAL controls when the Unreconciled New Layer filter list in the Layer Properties Manager is evaluated for new layers.
LAYEREVALCTL controls the overall unreconciled new layer filter list in the Layer Properties Manager which is evaluated for new layers. This system variable also affects whether the new layer notification is displayed or not.
Note: LAYEREVALCTL overrides the LAYEREVAL and LAYERNOTIFY setvars when LAYEREVALCTL=0. It acts like a global off (but not a global on). There is no effect even if LAYEREVALCTL is turned on if LAYERNOTIFY=0 or LAYEREVAL=0. LAYEREVALCTL must be set to 1 for LAYERNOTIFY and LAYEREVAL to function correctly.
Tip submitted by R.Williams
ACAD
9.2.2011    26536×
Share the tip:
applies to: AutoCAD ·
Back    All CAD Tips
Categ:
