CAD tip # 12803:
applies to: AutoCAD · |
Tip 9265: | RENAME on steroids - complex renaming of AutoCAD objects. |
Tip 8065: | How to add prefix or suffix to selected drawing texts? |
Tip 7892: | How to find blocks with an empty (not-filled-in) attribute? |
Tip 7890: | How to find missing numbers in a series of numbered blocks? |
Tip 7673: | How to search/replace tabs in texts? |
How to draw AutoCAD rectangle from its center point?
How to select a whole pipe line by selecting a single pipe segment? « | » How to reorder custom DWG properties?
Featuring: Use Google Earth images in your AutoCAD projects with the Plex.Earth Tools ![]() |
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
