Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 9228:
Question
You can use material definition (resp. appearance) to represent a 3D knurling on Inventor parts.
Create or modify your currently used Appearance and in the Bump map section, set e.g. the texture "Screen_2.png" from the standard Autodesk maerial library. This texture image can be found in the folder C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\1\Mats\. Similarly you can use also other textures.
The result:
knurling
Inventor
29.4.2013    35153×
Share the tip:
applies to: Inventor ·
Tip 14349:12 free material texture libraries for PBR rendering.
Tip 14281:Mapped network drives (S:, T:, X:, etc.) are not available in my CAD application.
Tip 13824:How to export OBJ including materials, textures from Inventor?
Tip 11464:How to make a fast Inventor Studio animation without rendering?
Tip 9842:Interactive cloud viewer for 3D CAD data in Autodesk 360.
Back    All CAD Tips
Categ:
LogOff 2006 More info
