If you need to exclude some parts (e.g. entourage) from calculations of the total mass, COG or inertial moments of your assembly (3D model), set them as "Reference".
Components marked as a Reference are not taken into physical calculations (as if they have null mass, zero material density) and they may not be listed in the BOM.
Select the non-participating components in the assembly browser, right-click and choose BOM structure > Reference. Alternatively you can use the dialog "Bill of Materials" (Assemble > Manage > Bill of Material) and the column "BOM structure". After you change this setting, recalculate the new, lower net mass (weight) of your assembly using Manage > Update > Update mass.
If you need to display reference parts in drawing views with a continuous, non-dashed linetype, in the dialog "Drawing view", in the tab "Model state", choose the parameters "Reference data":"As parts" and "Hidden line calculation":"All bodies".
Another option is to manually overwrite the mass of the entourage subassembly or part with the zero value (0):
Featuring: Simply link AutoCAD LT blocks to Excel table data. Excellink LT 2006
