Over 1.092.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 10791:
Question
The CAD/CAM/CAE application Autodesk Fusion 360 automatically switches to the appropriate graphics acceleration mode. If your graphics card (or rather its driver) shows display problems in a particular DirectX mode, you can switch your Fusion 360 to use a forced graphics mode DirectX 9 or DirectX 11.
Choose "Preferences" in the menu under your login name (upper right) and under the General tab switch (from the value "Auto-select") to the selected mode in the field "Graphics driver".
Fusion360
12.3.2016
12526×
applies to: Fusion 360 360 ·
