Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 9788:
Question
With the freeware utility CADstudio ImportCoord for Inventor, you can read 2D and 3D sketches or work points defined by XYZ coordinates from Excel. If you check the options "3D points" and "Use names" and specify the Excel column number containing point names, the imported workpoints will be named accordingly from Excel.
Download the free ImportCoord utility from ImportCoord. After you load the IVB project into Inventor (VBA Editor), run the VBA macro with Alt+F8.
Excel source Imported workpoints
Inventor
17.4.2014    9649×
Share the tip:
applies to: Inventor ·
Tip 2231:How to read a coordinate list into Inventor (sketch)?
Back    All CAD Tips
Categ:
