Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 7025:
Question
The symbol for surface roughness and machining parameters is included in the mechanical version of AutoCAD - AutoCADu Mechanical. See the AMSURFSYM command (ribbon Annotations).
To draw the surface symbol in a plain AutoCAD or AutoCAD LT you can use the dynamic block Roughness from the CAD Blocks library. It conforms to the ISO 1302 standard. Insert the block in the standard way, select the type of symbol (visibility state) and double-click the symbol to enter the requested descriptions (attributes).
Roughness symbol
ACADACLTACADM
30.10.2009    54010×
Share the tip:
applies to: AutoCAD · AutoCAD LT · AutoCAD Mechanical ·
Tip 14509:AutoCAD linetypes - the A/R/U orientation options in complex text-linetypes.
Tip 14503:Compare the performance of creating arrays/patterns in Inventor.
Tip 14443:Connector, notch, groove, cutout or other curve- breaks - easily with dynamic blocks.
Tip 14264:Extruding from an object in Autodesk Fusion.
Tip 14215:IF statement in AutoCAD text fields and attributes.
Back    All CAD Tips
Categ:
VRMLout More info
