  Visitors: 6804
CAD tip CAD tip # 13032:
How to prepare a 3D model for manufacturing by removing detailed elements?
A - answer The CAD/CAM software Autodesk Fusion 360 has several tools for suppressing features on the model - e.g. for simplifying the model before manufacturing.
In addition to the ability to select a model wall and suppress it using the DELETE button, we also have an automated tool that can search the model and conveniently suppress the elements found (e.g. any small ones). Automatically or manually suppressed elements are stored in the Design History and can be undone at any time.
The procedure using the MODIFY > Simplify > Remove Elements function is described in the video. Towards the end of the video, the procedure for activating this functionality if it is not offered to you is also explained.
Fusion360
100% *  CAD,CAM
14.8.2021    1461×
Prices - CAD eShop:
applies to: Fusion 360 360 ·
Tip 13766:Edit the Fusion 360 CAM tool library using Excel.
Tip 13174:Transfer electronic designs from Tinkercad to Fusion 360.
Tip 12297:Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility?
Tip 8901:Generate CNC codes online - easy manufacturing of 3D CAD models.
Simply link AutoCAD LT blocks to Excel table data.
Excellink LT 2006 More info
