Over 1.092.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 7468:
Question
Prepare a script file (the .SCR extension) where you set the requested system variable. This file is a plain text file with a single line - e.g. to "myscript.scr" insert:
HPNAME myhatch
Save this script to the AutoCAD program or support folder.
Then add the string /b myscript.scr to the AutoCAD runstring (the desktop icon, right-click to Properties > Shortcut > Target) -- this will run your script file automatically when you start AutoCAD - e.g.:
"C:\Program Files\Autodesk\AutoCAD LT 2011\acadlt.exe" /b myscript.scr
ACADACLT
23.7.2010
10282×
applies to: AutoCAD · AutoCAD LT ·
